Did I get the right AC compressor
tampa fl
I got the compressor from coolstream for my 93. There is obvious difference. Idk if I need to swap the top part of the old one to the knew one or if the new compressor just isn’t going to work for me? The new compressor is Denso the old is oem. I have the r134a system. Any help is much appreciated.
Thank you. I just wanted to be sure. I also
noticed the electrical connector was different.
Just a one-wire hook-up, so nothing to confuse. Easiest thing to do is to cut the old pigtail off the bum compressor and solder it onto the lead off the old one to make it plug-n-play.
That plate on the new one looks like some sort of test plate and maybe you're supposed to swap your old one? I don't even see the 'high: side connection on the new one.
Remove the shipping plate and put the manifold from your old compressor on the new compressor. This is common practice. You'll need a new gasket for the manifold, the new compressor may or may not come with one.
Wiring and 'plug' is not an issue. It's just a single wire. Clip the old plug off, put it on the new compressor.
