Did I do this right?
New Zealand
1993 1FZ-FE (JAPAN)
Deleting EGR and VSV and Pair
Both EGR Plates are in. Just making sure these vacuum lines are right.
Rig dies right away after start up.
And yes the Vacuum line below the IAC and TPS is still there.
Brake booster line is still in.
Is it something to do with those vacuum part that goes into the block?
the vac hose from the fuel pressure regulator to me looks to be going to the wrong port. on my 80 the vac line is a short one just above the fuel hose return line just like the one in this pic
I’ll suggest capping both ports on the VSV. Did you install a new gasket under the plenum block off plate?
I also did the Valve cover gasket and spark plug gaskets.
I got it to run for a moment and it seems like a massive vacuum leak. Just will not idle but under abit of gas she seems alright.
Might have to go back and have a look at spark plug gaskets
