Diagnosis help- slight engine miss...
Bellbrook, OH
Our '97 w/ 135k- stock- developed a slight but consistent miss yesterday while the wife was driving. No CEL. It feels like a cylinder missing intermittently, both at idle and under load, but not all the time- meaning maybe 30% of the revolutions. I thought HG, so did bubble test- nothing, but remembered it needed to be hot, so that's inconclusive. Will do again tonite. No smell or liguid out the tailpipe. Took off heat shield to look around exterior of engine- nothing to note there. Coolant is low, but for 3 yrs, it very gradually goes low- like a half reservoir tank a year.
I changed the air filter 2 months ago, removing the intake hose, being careful not to bend it and it was fine until yesterday. No code reader and i've not pulled any plugs.
think i'd start at intake hose, then what? ideas? thanks...
So you can predictably get it to miss?
Any correlation to anything, heavy load, up hills, when you're wearing brown socks, no socks, etc?
Sounds like a fuel problem since you're dealing with a distributor...check the injectors and maybe do a wiggle test on the injector harness. But I'd still do the simple water test of the plug wires to see if you can get any arcing.
You familiar with this type of a test?
I'm curious of what you're talking about SBFJ60FIG
To simulate a high-humidity starting situation you soak the high-tension cables (aka spark plug wires) and cap, and coil wire with water, preferable when it's a little dark out so you can see arcing and just look for little blue lightening bolts jumping off the wires when trying to start the car or while it's running/missing. You can hear it too if the wires are arcing, it will sound like short snapping noises when they jump-to-ground.
I suspect this is not the issue with this truck since it's intermittent but still a thing that could be checked to rule out.
If you've got bad wires your truck will be hard to start and or miss until warmed up on days when it's raining or super humid.
That clear it up?
Inspect the main engine wiring harness as it passes close to the EGR valve.
-B-
thanks beowulf, will do that...
more info-- ran it til t-stat opened and didn't see any bubbles except one or two at the beginning of the test, which i assumed was just air in the tube/radiator. none after that.
it gets worse as it heats up, and is completely fine when started and ran cold. i pulled #3 plug and other than the gap very too big, plug looked fine, if a bit crusted w/ white crust. need to pull that #6 and look.
i have a medium bit of auto work exp and it SEEMS to be ignition miss, rather than gas, as it's a sharp on/off, not a chugging like gas...
Seafoam or Marvels
I bet you have some trash and or water in your gas system. Put some Seafoam or Marvels Mystery oil in the gas per directions. Dollar to a doughnut, in 50 miles no miss.
Grouseman
Can you repeat the condition with power braking? This torques the engine enough to stress the ECU harness near the firewall (under the heater valve).
yes, i can recreate it with power braking. and now i have the CEL with a reader coming tonight, so hopefully we'll see. it's getting worse as time goes on and more consistent. it also gets worse as the truck heats up and is better with a very light foot, to the point that it almost runs fine with a very light throttle.
Mine has always had a very slight miss. Irregular.
Even after a complete tuneup, cleaned TB, everything checks out.
My belief is that it is just standard for these engines.
Never hurt anything and runs smooth as a baby's ass in every other respect.
My $.02.
Ok, that's a good start.
Now do this: see where you're heater valve is located with the couple of bolts on the firewall? Remove them all and let the harness sorta "relax" a bit and then retry the power brake test. The harness maybe coming in contact with the hot EGR pipe so try to move it away from the pipe if possible.
Report back on your findings.
Thanks.
To illustrate, notice the main harness enter the Black heater valve from the left.
thanks- will try that. though i don't think the harness is it, as it will hiccup just idling- and badly. i'll of course try it though to rule it out. it's now bad enough that when warm, it will barely make it up a decent grade- won't go over 40mph. misses constantly. my reader didn't show up yesterday and now the CEL went off, oddly enough, but will get to it here soon-- work, etc... i've now run enough shell gas thru it and injector cleaner a couple months ago that i'm pretty sure it's not just a batch bad gas either.
more info...
OK- so the diagnosis according to the codes was a P0133- which is a 'slow reaction' of the front O2 sensor. The real-time readout showed no ignition misfires, though i'm not sure what that means-- meaning how far down the ignition chain would it detect a miss? does that mean it knows its creating spark all the time? it wouldn't know if a plug was bad, right? all other readings were normal.
so.... i just got the O2 sensor from Cdan and just put it in. no difference. my mechanic bro-in-law thought a fuel filter, so i ordered one and will put it in tomorrow, if time. only, if that were it, wouldn't it miss all the time, not just when hot?
i visually checked the intake hose and it 'looks' OK.
any other ideas...?
we've had it since 96k and it has 135k now. never did plugs, wires, rotors, etc. and don't have history before that. could be original and they look old. though its reading no misses....
help...?
Hey bro,
My '94 had the same exact problem. Missing at low idle, accelerating under load, cruising on the freeway all of a sudden. Then as soon as it came it goes away.
I took it into the Japanese car repair shop where they replaced the "IDLE AIR CONTROL VALVE" at $720 labor included my problem was over. The IAC alone costs $550 and is a little smaller that a can of Red Bull. Whatever route you go it'll cost a few pesos. Problem fixed.
any other ideas...? help...?
You have had 2 or 3 recommendations above to check your main engine wiring harness. The following "Cause" and "Solution" text also points you to the wiring. Start at the connector and wires by the Bank-1 O2 sensor and if that all looks OK, move to the main engine wiring harness. I think you will be wasting your time replacing the fuel filter but go ahead if it makes your mechanic friend feel better.
Causes
A code P0133 may mean that one or more of the following has happened:
* The oxygen sensor is faulty
* The wiring to the sensor is broken / frayed
* There is an exhaust leak
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back.
If the code comes back, the problem is more than likely the front Bank 1 oxygen sensor. You will likely wind up replacing it but you should also consider these possible solutions:
* Check and fix any exhaust leaks
* Check for wiring problems (shorted, frayed wires)
* Check the frequency and amplitude of the oxygen sensor (advanced)
* Check for a deteriorating / contaminated oxygen sensor, replace if necessary
* Check for inlet air leaks
* Check the MAF sensor for proper operation
'97 LC w/ 130k. Unlocked, fake wood, oem tires, pink panties.
If it is a LC and you have the pink panties then discard them. The pink panties are only for those with the LX450. This is not funny and it is not a joke.
-B-
wow- stern warning of the 'pink panties' use. Duly noted.
Yes, I have glanced at the wiring, but not to any serious degree, as the engine was hot last night. I know that needs to be next and will be doing that tonight when I change the plugs and check resistance of wires. Plugs, sensor and filter I believe are prolly all original, so changing them doesn't really hurt either bank or vehicle. thanks for reminder.
Since you are going to discard those pink panties, Dan is collecting them. Send them to American Toyota. They'll get to him.
There are several tips on replacing the fuel filter if that is what you decide to do. It is a PITA on the 1FZ-FE.
You will need to inspect the main engine wiring harness carefully. This means getting up in there with it, removing the factory heat shielding and convoluted tubing and inspecting individual wires. The primary trouble area is where the harness goes by the EGR valve. Another problem area is behind the glove box where the harness passes through the firewall. Use new wire wrap and seal with heat tape. You can get the ThermoTec brand heat tape a speed shops and places like that. You can also order on-line at places like Summit and Jeggs.
-B-
ok, now, i've visually inspected the harness and of course it looks fine. question please--- how and what would happen to the thing? it's completely covered in black plastic and tubing. i don't even see how to get that nice factory black cover off?? but i will do as told and tear into it... :(
in the mean time-- replaced fuel filter and no difference. just switched out spark plugs and tested resistance of wires and all were in the 9 to 18k range, with lowest resistance near the front of the engine-- interesting, and consistent with heat breaking down wires and their conductivity. of course, one wire broke, so have to wait on parts now... plugs looked fine with very large gap. will post pic. oddities... 2 or 3 of plug holes had copious amounts of oil in them. not standing, but very wet. it apparently didn't seep into cylinder as all plugs were dry. thoughts on what is happening there?
re: air intake tube. took it off and wiped out and inspected. no cracks or leaks. did a water and light test. don't know what else to do. don't think my symptoms are those of this prob. as others have reported erratic running all the time, which is not what i have.
will keep updated after i get wires... argh.
forgot to add... took off cap and it looks new. no scoring, char marks, etc... spring is fine in center. rotor looks new as well. will not be changing and am ruling those out. also took pic of throttle body and it was very clean on the intake side. of course on the other side was another story, but i was pleased with how clean it was after seeing other pictures.
