Diagnose this sound
Panama City Beach, Fl
Driving through the hills, lost power, engine real rough. (94 unlocked, no major mods, 245k).
Recording is first at tail pipe then at engine bay.
Dang it, file won't attach. Sounds like a phfft phfft phfft at the tail pipe, less at the engine bay. Is this the head gasket failing?
Is it a random pattern for the sound, or is it a pretty constant rhythm? Constant would indicate that it is the same cylinder misfiring. Could be a bad plug, plug wire, bad dizzy cap, loose plug, If so, then pull one plug wire at a time to see which cylinder it is. Check all the regular suspects for head gasket failure. Milky oil, low coolant, etc.
I found that a couple of my spark plug wires popped up this week. I checked compression the other day and then oil got all over the valve cover. I sprayed degreaser and water on the valve cover channel where the plug wires run. My wires are old and must of let water get into the spark plug holes and steam pushed them up??? I cant think of any other reason they pooped up. I heard the light thud thud thud sound up front. Nothing from the rear.
I didn't find anything loose, had AAA tow to my local shop and they have it running well after a tune up, plugs were fouled (my father in law uses it as a golf cart to the barn). Also having them replace the power steering pump and high pressure lines while it's there. Looking forward to some good camping and fishing with the dog this spring!
