Detroit install question
ARC
Central Kentucky
I have a few questions about a detroit going into a 78 FJ40 rear third.
There is a hex bolt that holds the pinion pin in ; to install or remove this you must remove the carrier bearing cap?
Next it seems the pin cannot be fully removed because it hits the ring itself about 80 percent of the way out?
thanks
David
thanks
David
I don't know what a carrier bearing cap is but I know you have to rotate the carrier to get the hex bolt and the center pin out
Yea, it can be a pain. I used a die grinder, and cut in a little groove on the cap so that the allen head screw can still be threaded out without removeing the bearing cap.
I was always able to get the pin out with my 4:11 gears, although I worked on a rig at the RoundUp where It took a punch to get it out the rest of the way.
I have just changed my 4:11 out to 4:88, and I had to clearance both the pin, and the gear a little bit.
aw
