Detroit Disc Brake rear axle, LOADED!!!
Long Island, NY
1976 FJ40 housing, setup for spring over, sway bar mount, custom heavy
duty shock mounts, FULL disk brake conversion completed, rotor to rotor
with calipers, lines, and everything- ready to plug in.
Newer stock pinion and ring gears, and newer full detroit locker, heavy
duty axles. Only 200 miles on the entire setup, brake pads are hardly
worn.
Plug in and bleed - your ready to go.
Located in Colorado Springs, Colorado. The disk rotors have surface rust
and need to be turned at your local shop.
650.00 Or best offer. Plug in and go! Only 200 miles on the setup.
Thanks,
ragman
If you are interested in parting out, I would be interested in the RDB conversion. I already have a SOA rear with a detroit. Let me know.
-Brian
