Desmog question - Distributor Venting
Lancaster, PA
Hi all,
Been searching and reading so much my head is spinning!
I am helping a friend from the club go back to a factory carb from a Weber that the PO installed. The PO pretty much ripped everything out and we are working to gather the necessary pieces.
Thanks to Jim C and all of those who have worked through this previously!
My question is on distributor venting.
Can we vent it to the air cleaner with a one way valve inline instead of the VCV? Wouldn't this solution also keep the gas fumes from pushing back into the distributor?
Thanks!
Andy
Wouldn't hurt. I don't even know that you need a check valve. I would install one of the OEM distributor filters or something similar in-line with the IN port of the dizzy cap, though.
Thanks!
Andy
That would be better than nothing, but the stock venting system using the VCV is designed to use intake manifold vacuum to actively suck out ozone-laden fumes from the distributor. Your way just leaves a way for the air to get out, with no impetus to get it out.
