demons (rant)
Granger, IN
I bought my 80 about a month ago. Everything worked fine in the last week I have had
1) DS power window quit working ($300 for a new master switch)
2) cruise control works intermittantly (not really important, just makes me worry what else is going to go wrong) worked again after I turned it off and let it sit for a while.
3) occasional idle problems. It will idle down to about 200rpms and sound really rough or it will completely stall. After I turned it off and let it sit for a while, when fired back up, no idle problem. I've searched a bunch on this one but seems that no one has found an answer yet.
:mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad:
Anyone??????
Wow, esoteric failures and an intermittant problem on a 14 year old vehicle. Who would have seen that coming?
The master switch probably could have been repaired for 0$ or at the very least a used one could have been sourced from one of several parts dealers.
Cruise control: check your brake fluid level. If the BRAKE lamp on the dashboard illuminates it will cancel CC operation. On occasion the level sensor in the brake fluid reservoir will fail and the lamp will dimly illuminate. If that's the case, replace the cap with a new OEM one. Do some searching on this board for other causes and easy repairs.
Rough idle/stalling: You didn't really search at all, did you?
On the cruiser control thing. Mine flashed at me the last time I tried to use it. A search revealed that if you pop the triangular cover on the actuator (passenger side under the hood) and jiggle the cable a few times you get a temp fix. It worked. I just finished reading a long and detailed thread about idle problems similar to yours. It turned to be that a wiring harness had been damaged by heat:
https://forum.ih8mud.com/showthread.php?t=61744
Karl
Karl
Thanks Karl
I had actually been reading that exact thread and must have got distracted before I got to the end. Thanks for pointing it out to me again. I guess I need to go look at my wiring harness.
Thanks again for the helpful reply
i fixed my rough idle bu cleaning the TB and running a tankfull of 97 octane gas, and techron.
Agree with the others. All fixable. Master switch disassembles and has large metal cleanable contacts - 30 minutes. Low idle is likely the throttle butterfly valve which has a nice beard of oil and grime on its edges - 30 minutes. Cruise fix already cited - 3 minutes.
DougM
DougM
Or idle can be affected if the big air intake hose to the air cleaner is cracked or broken.
Thanks for the suggestions everybody. I know that I'm driving an older vehicle and should expect things like this to happen. I just didn't expect them all at the same time.
Guess I just need some time to go check it all out. If any of you know where I can find some of that let me know.
DougM
Is the master switch the one that is right below the actual window buttons? or is it the black box that mounts lower and says "door control" on it?
Master switch is the bank of 4 window switches on the driver's door armrest. Sounds like you've identified this as the problem. It can be opened up and cleaned.
DougM
