delay when manually engaging overdrive
hampton, VA
So, my transmission shifts into overdrive as soon as the engine temp hits 128F. If, however, I manually disengage overdrive, and then re-engage it, there is always about a 5 second delay before shifting into OD. It has done this for the entire 7+ years I've had it. Is this normal?
I don't know about 'normal'....mine shifts (manually) in about 1 second. But..it depends on 'parameters' (throttle position, engine rpm, gear selected). You might double check your throttle cable adjustment and trans cable.
