I'm looking to install a factory defroster switch in the dash to control my battery seperator. I got the switch and about two inches of the harness from a boneyard. It came out of a 2nd/3rd generation 4runner. Part # appears to be 386-0v55.
Here's the pinout and color combo. I'm not sure what colors do what. One set of wires controls the dimmer, one does the indicator lights, one to energize the switch and one for ground.
Wires are as follows:
pin1: Green with silver spot
pin 2: black with orange stripe, silver spot
bottom row
pin 3: blue with white stripe, silver spot
pin 4: white with green stripe, silver spot
pin 5: empty
pin 6: black with yellow stripe, silver spot
Here's what I get when I test with a multimeter
WHen switch is pushed in, I get continuity from blue/white and black/yellow. That goes away when switch is cycled to the out position.
With the bulbs out of the switch, I get the following:
blue/white
green/silver spot: continuity to silver terminal on light socket for illumination
white/green stripe continuity to brass terminal on light socket for illumination
black/orange stripe continuity to silver terminal on hot/illumination light
black/yellow stripe continuity to brass terminal on hot/illumination light. This also closes contact to blue/white.
bottom row
pin 5: empty
blue/white
