Decision On What To Do First
San Diego
Hello All,
Just interested in some opinions here on what to do first on my recently purchased 97 LX450. It came with fresh Nitto 285/75R 16's on it and all I really want to do for now is put a 2.5" OME lift and an ARB Bull Bar on it. What should I do first? Also, I wasn't planning on a winch in the future but I'm might have an addiction to feed later on - do I get a "winch ready" bull bar in case I change my mind?
Suspension first, then a winch ready ARB bull bar
Well, I have learned from reading lot's of post here with your same question.
Be advised that this truck will run you to the ground money wise if not careful!
1st off base line if not done,
2nd Plan your mods wisely becuase there are lot's of things you can do "WHILE YOU ARE IN THERE"
3rd figure out how much gear you are going to haul and factor in all the armor you will add. This way you can determine how much lift you will need. I had 285/75/16 on mine and they dissapeared when I lifted my truck. I went with a 4" so that later I would be able to run 35" tires.
Last, my reccomendation is for you to get sliders first. This way you can start doing some mild wheeling and not have to worry about bashing your running boards. :cheers: and welcome:flipoff2:
I would say baseline your truck and get the truck in top working condition before getting into mod. Then lift, follow by ARB winch bumper, slider, winch, snorkel, rear bumper carrier.......... :)
First of all, thanks for the replies so far! I know i'll probably receive a ration of s**t for this question being a NOOB and all, but what do you mean by "baseline" the truck? And I'll clarify my situation here - I have a WIFE and 3 kids. Notice the wife in BOLD. My first mission was to get her to "buy into" the need for a "LC", done! Now the hard part - the mods. I am looking forward to getting the whole family involved in Offroadin'. As this happens, it will get easier to convince her on the need for mods. I've already shown her photos of ROMER's rotw( i have the same rig) and how a 2.5" lift doesn't change the look all that much. Anyway, I'm sure I'm not the first person in this predictament. Looking forward to your comments.
Baselining means going through the whole truck and changing fluids, fresh plugs, wires, cap and rotor, collant flush and fill, new hoses, etc.....
Look in the FAQ section there is a new owner guide or something like that. Also try using the search function, it work very nice.
Also, when you get ready to order parts, go straight to the phone and call Dan at American Toyota (listed in the vendors section) he will get you squared away. Plus MUD members get a pretty nice discount.
Good luck and welcome!
First of all congrats on the purchase.
Assuming the vehicle is baselined the first thing I would do is protect my investment with an ARB bull bar to save you in situations like:
https://forum.ih8mud.com/chit-chat-section/50707-daughterofromer-learned-value-armor-accident.html
If you have any inkling of getting a winch in the future get the winch bull bar. There are a lot of threads out there which start like...."Can I put a winch on my non-winch bull bar?"
Remember when you decide to do a 2.5" OME lift don't forget caster correction.
Good luck...
You should know, these guys here throw around the word 'baselining' like it's no big deal. In fact baselining a truck from top to bottom can cost as much as a new ARB bull bar. It all depends on your tolerence for wallet pain. Synthetic fluids will cost you. Factory plug wires aren't cheap. Many will say a full birf job is part of baselining- and expect to pay $400 to do that job YOURSELF. More at the dealership, about 3x that amount.
You can cut corners. IE: skip the birfs until they NEED it. Use 'regular' oils instead of synthetic. But, you really should flush the radiator, change the crank case oil, differential fluids, x-fer case fluids, maybe even transmission.
I don't consider using "regular" oil or fluids to be cutting corners, but you do want to swap out all fluids, change the oil and fuel filter, and change the pcv valve, check the brake pads for wear, grease everything that can be greased to the right level at a minimum. From there, do a tune up: new plugs, distributor cap and rotor. If you need new wires, use OEM and change those out, too. Check the battery. Now you've got the rig in a situation where you have a good handle on its general health. As you drive it more, you'll get a better feel for what modifications you want, and what expectations you may have. But, you definitely want to change the fluids, because you have no idea how long they've been in there, or what quality they are.
I guess most of us are a bit extreme when it comes to keeping the truck in top shape. Assuming your brake are in good condition. If not, all 4 rotors, pads and shoes with calipers rebuild kit will set you off for around $500+. For complete flush and fluid change will run about $250 with all synthetic fluid and Toyota Red coolant. Complete birfield repack will run at least $300+. Air filter, wire, plugs, distributor cap, rotors another $140. More for radiator hoses, thermostat, and all the hoses, Phh if you are maintenance freak. Starter rebuild and driving belts. You are almost done for a complete "baseline" job. Just to give you an idea, parts for this rig is not cheap that is why it is built to last. After all that, you are good for another 10yrs or more. Some guys might go as far as replacing Head gasket as well. :)
Here's what I've done. It's worked for me.
(BTW, I've been been baselining my truck as I go along. Unfortunately my tolerance for wallet pain is fairly low. :frown: )
1) Body lift (1")
2) Grey wire mod
3) Tires (315's)
4) Suspension lift (OME Medium)
5) Belly skid plate
Planned upgrades (in rough order):
1) Rear overkill e-locker protection (about 40% done)
2) Reroute exhaust over frame rail and cut and turn cats
3) Rear bumper and quarter panel protection
4) Sliders
Would like to have upgrades:
1) Roof rack
2) Front bumper
3) Other misc stuff.....
So far it's working pretty well for me. :)
I already have a pretty good start then on "baselining" this thing then. After driving 450 miles to pick this up, the first thing I did was drop it off at my mechanics shop. CEL came on 60 miles from home - EGR modulator ( replaced w/blue one ), new front pads & resurface rotors, flushed/replaced coolant, new syn oil, replaced both diff fluids and tranny case - $750 so far .... the pain has begun!
Get a winch ready bull bar..you wont regret it.
