Dealing w/ rust & bare metal
SoCal
Unerside of tub, vintage '74 FJ40. Areas of rust spots and bright, bare metal. What do you do to get it ready to prime & paint?
Second, much of the what I presume is the original undercoating remains. Can I just paint over it or does it have to, ugh, come off?
Vic
Redlands, CA.
It sorta depends on what your going to use for paint. I am using zero rust as a paint finish/primer. I use the prep stuff made for zero rust. Its a powder that some say is TSP. It is mixed with water. I spray it on the area to be cleaned and then use a nylon abrasive cup brush in a drill. I do a section at a time, then rinse the whole panel with the prep solution. I let it dry and coat with 2 coats of zero rust. I read you could also use a pressure washer after the abrasive rust removal. With zero rust you don't have to remove all the rust, just the loose stuff.
Hi All:
Depends upon what you are trying to accomplish.
Temporary finish repair to stop the spread of rust? Wire brush off all of the surface rust, clean with a degreaset like "Simple Green," dry, then paint with a rust-inhibiting paint.
Long-term preservation of the body tub? Remove body tub from chassis, sandblast the body, then carefull prime and paint, coat the underside to protect the paint from road debris damage. Derust and repair the frame, paint and coat.
Having the body tub off of the chassis makes a through good much easier.
Good luck!
Alan
Seattle
