Dead truck
San Juan Puerto Rico
Website
www.facebook.com
Dead truck, Alternator?
I need to confirm this, my truck is dead right now. It started, I noticed that the lights were dim, the volt meter showed less than 12 volts and would not go up. finally died and all it does is click, click. My guess is the alternator, what do you guys think???:confused::confused::confused:
Sure sounds like a flat battery / battery not being charged. Without you performing some voltage tests and jump starting the vehicle it's hard to pinpoint your exact problem............corroded connections, bad battery terminal, fusible link, brushes, regulator etc etc.
Don't jump to conclusions. Start with the simple stuff like corroded battery terminals, bad battery, bad primary wiring before tearing the truck apart to replace the alternator.
DougM
Tomorrow morning I'm going to get it jump started. One weird thing it was doing was that the cd player was going on/off; like it needed more juice. The radio was ok.:confused:
As has been said, check for corrosion on your wiring especially by the battery. It seems, though, that if the corrosion was the issue, the truck wouldn't have started in the first place and likely would have stayed running if the alternator was providing charge to the system.
I had a work truck one time that I started in the morning, and left for work. It was dark out and I noticed that the longer I drove, the dimmer the lights got. The truck started to struggle about 1/4 mile before I got to work and just made it to my office. When they tried to start it, the battery was dead--alternator was shot.
Battery contacts are new and clean, the two things I'll check tomorrow, if I get it going, are the battery and the alternator.:hhmm:
If it is a bad alternator, does any one knows if there is a GM alternator that can be fitted to the 3FE? How about the 1 wire setup?:hhmm:
My alternator has been going for about two years now, sometimes I get the lights, and only on start up. They never stay on, and usually go off after a second or two. I haven't gotten the lights in a few months now, but I have noticed that on cold days(say 5 or 10 degrees) that running the heater while the lights are on, the alt. gauge will drop down to the bottom line and the headlights dim way down. The radio thing is funny too, for the last 4 months mine will mysteriously turn off, then back on. It never stays off longer than a minute though, and I have always contributed it to the alternator not putting out enough.
I have a new alternator ready to go in, kinda waiting for it to warm up a little, above freezing would be fine. Its the upgraded 90 amp version for the 3FE. From what I have learned, it doesn't just bolt in, it looks like you can grind a little and make it fit, or there is a bracket for like $25 that you can get. I think I'll get the bracket and paint it yellow. The alternator part number is 27060-61100-84. Has anyone used this alternator and the bracket?
Since I recently hit 300k on the meat wagon, I have decided to give her some love this spring, bet you wish you had these Mr. Vazquez:flipoff2:
The diagnostic just came in... I need an alternator. Tomorrow I'm removing it, Monday is getting rebuilt. Mine is the 90 amp. Is there any way to increase the amps on an alternator while being rebuilt???:hhmm:
Just removed the old alternator, and found a "great" surprise! A Bosch alternator, Nooooo!!!!!:eek::eek::eek::eek::mad::mad:: Now that's the one I have to rebuild, I'll see what the boys at the alternator shop can do to make a Bosch piece of $#@% become a decent alternator!
PS: Mr Toyota could not find a worst spot to put the darn alternator! Why not keeping it in the top!:mad:
