Dead Headlights
While my dimmer works on the '79 I have always wondered if the springy feel when pulling it back to low (and passed) is for some type of flash to pass feature, although I see nothing on the wiring diagram to indicate such a feature.
While I have the steering column cover off at the moment I haven't looked to see what access there is to the wires, other than the harness coming up from under the dash. So I'm not certain how hard it would be to use a multi-meter and/or a light bulb to validate a good wire/broken wire.
First off I have to say that those of you that are good with electrical, my hats off to you.
Yesterday I took my '73 FJ40 to a friends for dinner, no issues noticed but it was still daylight. When I go to leave, it's dark now, I have no headlights! Every other lighting device is working perfectly. Lucky for me my KC Daylighters got me home after I adjusted them to blind on coming vehicles.
Today I've been trying to track down the source of the issue. Here is what I've done so far:
Checked both fuses and they are good.
Check both headlights and they are good.
Removed, disassembled, cleaned, lubed and reassembled the headlight switch. I did find that the illumination bulb was toast so a replacement will be picked up locally tomorrow.
I have power at the fuse panel on the power side but show no current flowing through the fuse when the light switch is in the run position.
I've tried the dimmer switch in both positions and nothing. I'm not ready to tear into the column to clean and lube it just yet.
I've search a bunch of threads reporting the same issue and the best info so far seems to be a bad ground. One poster mentioned that the headlights grounded to the fender. I've followed the harness from the headlights back to the firewall and can find anywhere the white/black ground wire comes out of the bundle to ground.
If anyone can point me to the spot this happens so I can double check the ground I'd be grateful.
Do u have Key Off Power B+ to the Solid Red & Green w/ red tracer stripe terminals at your headlight switch connector where it plugs into the back of the headlight switch ?
Yes. Yesterday I removed the turn signal/dimmer switch assembly from the column. I inspected everything and tested for continuity, cleaned lubed and files the contacts for the dimmer. Everything tested OK and appears to be in working order.
At this point it seems that there must be a break in the power wires going to the headlights as there appears to be no other reason for them not working. It seems I have a decision to make, either I tear into the harness to find the break or run new wires for the headlights. Time to step back and do some more thinking.
ok.........
so my next step would be removing all the elec. tape from the headlight switch connector plug to where it intersects your main
harness upper LH side of your dash , this is only 6-8" inch's in length , look at the solid red wire in particular for being burnt and melted
this is a easy very Low intrusive inspection , Also look very closely at the 5 wires / terminals in the 6 bay connector for being melted
this is a very common problem have come across in the past
Post some photos Too for all of us too see and look closely at , that always helps
to be clear im talking about the connector that plugs into the headlight Pull switch far LH side dash , NOT the dimmer swicth
