I am new to this forum, I have seen a ton of great advise, now I am looking for some, I have a 75 FJ40, factory soft top with a 76 engine, I blew the head gasket, got all of the cooling problems solved
I noticed that the thermo nuclear reactor exaust manifold had a crack, why not run a header? bought a header, pulled the air pump, egr and most related parts have it all back together and running, still need to re build the carb, does a bit of over fueling, also should rebuild the dist, it needs it too, here is the question, should I leave the original dist and carb, if so what is the proper diaghram for hose hook up OR should I go get a non USA carb and non USA vac advance dist, if I do either, is there any reason why the computer still needs to be in the loop? Kinda long post, but I am pretty long winded. Any advise would be appreciated
Thanks for the help, I will be back, will pick up the parts this week and do the install this weekend.
