De-smog, carb, dist, header
I have recently bought a 78 FJ40 that was equipped with California emmissions. It was missing the smog pump as well as the dist. and some other smog stuff. My plan was to install the DUI Distributor, split header, and Weber 38. Can I make the stock carb work with all of the smog stuff gone?
Sure. Send it to Jim C. for a rebuild and drilling for ported vacuum. Tell him exactly what your plans are for the truck and he can build it/tune it to your needs.
Stay wit the stock carb. you can get a brand new one online from carberator.com I think it's called a buddy got a brand new one for less than 250 bucks not bad. Jim does a fantastic job as well, and will test and tune it for your specific needs
I don't think that you need to add a new port to the carb, because it may already have "ported vacuum". There are three brass vacuum ports near the idle mix screw and it would appear that the upper one may be ported vacuum. Ported vaccum is used for vacuum advance and it enters the throttle body just above th closed throttle plate. You can confirm its function by putting a vacuum gauge on it. Ported vacuum is zero at idle and increases with increasing air flow (eg RPM) through the carb.
fj40forlife said:
I have a Holley carb in mine runs great
What model and size ? I have a 2300 650cfm and it runs great but get 7mpg
I just bought a stock and waiting for the kit to rebuild it hopefully I'll se beter mleage
