Is there any way to turn off the daytime running lights I realize that they are the high beam bulbs and I've already burnt out a set of high quality high output bulbs.
Thanks in advance.
Thanks in advance.
It’s in the settings. Menu button will get you there.Is there any way to turn off the daytime running lights I realize that they are the high beam bulbs and I've already burnt out a set of high quality high output bulbs.
Thanks in advance.
There's also a hardware way to do it.
There's a resistor block about the size of a pack of cards. It's on the passenger side behind the headlight near the power steering reservoir. You'll recognize it as it looks like a heat sink with a metal perforated shroud around it. Unplug it and that will disable the DRLs.
I can disable them via vehicle settings on my 2010.^Good point. I don't believe the pre-'13 models has that soft setting.
If you have techstream you can use that on an 06. I did it on my cousin's 06 a couple months ago with techstream.What year do you have? Looking to do this for my 06, and wondering if it involves the same resistor, or if I'm pulling wires under the dash (or have to take somewhere w a techstream).
