Dashboard squeak..
Calgary, Alberta - Canada
I am getting frequent squeaks and rattles from the dashboard side right above the glove compartment. Gets louder when I hit a pothole or bump in the road. It seems like the bolt (or whatever) holding this side of the dashboard came loose. Any idea where it is located so I can tighten it up? I hope I don't have to remove the whole dashboard for this :confused:
It is a RHD vehicle but I think the dashboard mounts are the same as the FZJ80..
:cheers:
I had a similar problem with an 01 4R. The squeak/rattle drove me absolutely nuts.
I don't have a definitive answer to your question as problems like this could come from a number of unique causes.
What you may want to try is to have someone else drive your truck and you sit in the pass side and look for it. Good luck.
