Dashboard Light
SF,CA
I apologize in advance for this novice question and I’m repurposing an earlier post.
I’m installing an old OEM dash fog switch and I pulled the lower dash trim down. I came across this bulb in the dash. It’s burnt, but I can replace the bulb. Does anyone know where it goes?
I just found the bulb to the ashtray which I replaced (using the glove box bulb) but now I’m out of bulbs. If it doesn’t go anywhere noticeable then I’ll leave it alone and save a trip to the auto parts store, but if it’s visible I should get it while I’m in here. ( I was planning on splicing the wire to use for the light lead to the dash switch.
Deleted - Comment no longer applicable.
I think there was a ring light around your cig lighter. Your lighter looks aftermarket from the shot showing what I think is the back end?
That is exactly what it must be from! Thank you! The lighter was replaced with an outside temp gauge (not very accurate). I didn't want to close the dash back up with bulb that I could have fixed. Again - thank you very much.
Dan
