Dana 300 xfer
73lndcrsr
I just need a sanity check. I am working on a dana 300 and the rear output yoke is giving me fits. Can someone verify the threads for the retainer nut are normal and not left handed?
Unfortunatly I do not have the FSM for it.
Thanks for the help
Brad
I don't frequent too many others, I will try Pirate.
Thanks.
Me either. POR is prolly the way to go or if it's out of something common, maybe a local 4WD shop could answer it. We may be making a bigger deal out of this than needbe. Have you tried hitting it with an impact wrench? Do both directions and see if one works.
hit it with a 1/2" drive impact...hold the yoke in your hand WEARING A HEAVY LEATHER GLOVE, and let it buck...it will come right off.
Good luck!
-Steve
So far I am up to a 1300 LB/in2 3/4" impact. It won't budge. I will try some other things.
thanks for the help.
Brad
The line is 3/8" at about 105 psi and 13 cfm. Heat is next.
I am just afraid I am going to break something, other than the scresdriver that has already bit it.
I made a Bar about 24 inches long and about 3/8 thick,and about 2 inches wide, with a hole in the middle that i run bolts thru to hold the yoke, makes it easier to hold for us old guys.
Breaker bar and a Hi-Lift handle? The best combo ever IMO. You don't have that Heep 300 in you Cruiser do you? I don't know why anybody in they're right mind would do anything like that.
Thanks for the replies, I did not have a chance to try heat yet. I will verify the impact too. I thought I had enough air to it.
I am just helping a buddy out that is still wnating a Heep.
Significantly stronger/better transfer case stock out of the box than ANY one piece Land Cruiser case....better low range also. Many more upgrade options, for gearing, output shafts front and rear, yokes, front dig option.
A stouter, and more versatile case by far.
:beer:
Dana 300 is a good box. A buddy just broke front output shaft in his last weekend. But is running Dana 60 axles with 44" tires. Upgraded to big shaft kit, so it's even tougher now.
It will take alot of abuse for a small factory case.
J.R.
:beer:
Yep - only other "better" option is the Atlas and price wise the 300 wins, lots of aftermarket support, cheap to procure...
I'm almost jealous of my Heep driving buddies' D300 cases after seeing them in action twin sticked and 4-1 deep low. Makes there fairly stock CJs do some amazing things.
