Damn Grrr sound is back
sleeoffroad said:
Install the caster busihings first. If you have other noises then something else is wrong: Could be a lot of different things. Shock stems contacting due to washers not used correctly, sleeves on shocks bent etc etc:
Thanks Christo...
You and your crew are much more used to these kinds of issues/symptoms etc. than myself, so before I go any further, I will install the bushings and then see if anything is amiss with the (hopeful) return of a normal pinion angle.
Best.
-onur
Akron, OH
