Damaged rear tail gate
Beaumont, Texas
Website
www.marklowimagery.com
Well, this is the first time any body damage has been done to my cruiser and it made me sick. I was hooking up my 16' flat car hauler to the hitch and after lowering the trailer onto the ball, I did the chains and lights but forgot to flip the locking latch down. So when I was driving my 5-1600 class Baja Bug onto the trailer on the way to Baja, Mexico for the SCORE TECATE 1000, guess what happened. Yep, the front kicked up off of the ball hitch and when I realized what was happening, I hit the brakes which then rolled the trailer tung right into the tailgate just under the license plate. It went in far enough to crease the sheet metal and actually bowed in the whole gate but it still operates fine and seals when closed but I still want to replace it ASAP especially since I did the overall paint job about a year ago. I had to at the time blow it off at least until I made it back from Baja but now I am ready to take care of it. Just to see what a body shop would charge before I decided to do it myself, two of them said about $800 for a new gate shell and parts from mine and then paint which I would supply out of the same can the rest of the vehicle was done with so matching would not be a problem. So I then did some research on the internet and found a new replacement Toyota LC 1995-1998 complete tailgate in prime at a place called DTP ( Discount Toyota Parts) for about $265. I'm not sure if it comes with all the inside parts but the description sounds like it does but either way, I will have everything I need. Does anyone else have any suggestions for where I might go to find a tailgate or if you know anything about this DTP online store. Will it be actual Toyota Genuine Parts, same metal thickness as the original gate?
Mark
That sucks. I made the same mistake, except I completely forgot everything, I dropped the tongue on the ball and went to load my mini-truck. Fortunately I got lucky and the back of the trailer hit the ground and kept it from going anywhere.
Good luck with the repair.
I needed to replace both upper and lower 'doors' on my 100 due to a stupid maneuver I did last summer :mad:. I thought my body guy could just pull and fill but he said the rear door skins are actual high strength/tensile steel and are very brittle and not tolerant of pulling back out. Anyway hoser turned me on to this website
www.car-part.com and I was able to find the entire upper and lower door assemblies in perfect condition for just a little more than what Toyota wanted for just the skins...but it sounds like you may have found a great deal anyway! And it saved me money since there was a little less labor involved. And, in case the glass guy broke the rear window while removing I would have a spare window.
Just got it back 2-weeks ago from my body shop guy and it looks brand new again:).
