Damaged knuckle ball
Houston, TX
Im rebuilding a front axle for a project and came upon this knuckle ball that has been ground down by previous owner/"mechanic". The only reason I can come up with is maybe they couldn't get the birf back in??. It is about 1/8" thinner than the other side and the bearing race is starting to show. Would you run it or replace with knuckle ball from another axle? One benefit to replacing the ball is that I could go ahead and do a cut and turn and set caster while I'm at it.
Thoughts?
Last 2 pics are from the unmoddified side.
I haven't run this axle but the side with the ground down knuckle ball did have birf soup. Now does the knuckle ball alteration have anything to do with it? I dont know. It did have a Marlin HD inner axle seal installed as well.
Do you know any history on it?
... The only reason I can come up with is maybe they couldn't get the birf back in??. ...
Exactly, the only reason I can think of for that, would be a bent housing.
No history on it, purchased from a guy who had a pair of axles from an 80 he parted out. No other obvious signs of impact or damage to axle that might have led to a bent housing.
Is there a more precise way to check to see if the axle is straight besides just eyeballing it?
Using a relatively sensitive angle finder (like Magnetic Digital Angle Gauge) set the axle up level, then measure the angle of the upper knuckle races, they should be the same on each side. Sometimes, can see slight stretch (lower) bulge (upper) where the ball flange ends in the housing, a bit in from the weld.
