Damaged fender advice
Charleston SC
So when I pulled the flair I found some damage... When I bought the Beast I was so excited that I did not do my due diligence. I am ashamed. Still she is a awesome rig. So front fender looks like this. Would any of you try to straighten and pound out that mess? I have a replacement hopefully sourced but if it's not needed I would prefer to get my hands dirty.
I would try to straighten it out the best you can.
This is not the first time we've seen this on the forum. Tire blows apart, catch a rock or Boulder etc....
A lot of that can be hidden under/behind your fender and flair. Re seal your seam and then spray undercoating over the areas that might allow water in under the fender.
Just some thoughts.
Matching paint on a 20 y.o. rig can be difficult. Repainting can be $$$, on the replacement side of the house. If you aren't concerned you can get rattle can paint in factory (or any other color) colors and do it yourself. It won't be perfect but for the cost not so bad. Just do a search for factory colored spray paint. Replacing the fender is pretty easy, just get a high quality 3m or similar seam sealer to replace OEM sealed seams.
You could pretty easily beat on it and call it good as well. If it were me I would attempt to shape it on the truck, clean it up, prime and paint in place. Not a big deal at all that you missed it on the purchase, don't beat yourself up. When I was still learning I bought a rusty bronco that was so bad I wound up folding the body in half to take it off the frame.
I thought there was real damage to be seen. Mine did that too. If you're concerned about it remove the fender and tap it out with a cheap autobody hammer set from HF. Not like you're going to really mess it up, however, the inner fender liner at the bottom is peeled away and needs to be reglued. You will have to go to an autobody supply store to buy the adhesive. It's not really welded from what I can tell, just seam glued.
Thanks mudders. I will give it a go. I didn't realize that all of the gunk under there was glue. I will pull the panel and pound it out. Planning on welding the holes from the flair removal anyways. It's mostly a OCD thing. Once again thank you for the encouragement and the great advice. That's why this site is top shelf.
I understand the OCD part all too well. Good luck and post up pictures and progress.
