Damaged abs sensor
Germantown, TN
While preparing the lx for a knuckle rebuild, I noticed the drivers side abs sensor is damaged. I don’t have any codes or lights on the dash, so it may be ok at the moment. Looking for suggestions on what to do with this sensor?
Thanks
DannyG
The rubber boot is just a sleeve, There is a standard wire harness plug under it. You'll get a better idea of how damaged that harness is, if its unclipped, and the sleeve removed. Check the resistance across the sensor to see if the sensor is damaged or just the harness. .775Kohms is what mine read.
The harness is fairly simple to rebuild, I just did one of mine. But 50 bucks is a good deal; new, they are $230 and change.
