Use to build stuff all the time growing up. Tamiya mostly.
Short answer, same turn radius as before the add-ons because the wheel base and axle width did not change. But now the add-ons will cut a swath wider than the turn radius, which may end up passing over already cut grass.
I think.
If the steering rack was turning those wheels, yes. but in this redneck engineered contraption, no. See my follow up analogy above.Isnt Radius for cars is measured by your outside wheel, for instance my lexus can turn around in this street because the outside wheel will not run over the curb.... since the outside wheel is now technically the oustide wheels of the two attached mowers the turn radius should be wider.
Or am I thinking of this the wrong way?
fawk...I'd lose my mind if I had to drive that. If that's public transpo, then I'd get through a lot more podcasts for sure, but still not like it.1.75 hr commute
