VT,
You do realize that that table is specifically for what TDJIV asked. It will differ significantly based on what kibbles and bits you have. More specifically, TDJIV said he's running a 700r4. That slushbox when played out has a 0.70. fd ratio. Call it OD if you will. I also assumed he's running a stockish transfer case gear. And at the next to the end of the line is the diff. Which he states is a 3.40. The rest of the info is merely there to confuse the easily confused. So, based on what info was given and an assumed tcase ratio...all you need to do is add water and you get sea monkies.....or in this case pick your tire size (last variable in the mix) and viola you get actual...not theoretical, not GPS swagged real rpm vs speed data. Old f's like me don't know GPS from shinola...well actually we do...but in this case know what you have do the math add cheap Sun tach and your done.
And yes ...other ratios and any combination thereof can be easily calc'd...IIRC the TCLA.org website has a plug'in play.
perhaps i should have read the corresponding post
sometimes I wonder how I ever learned to walk.....
