D40 vs. SD40
Might want to change the title to say 1 BBL carb. I bet there aren't a bunch of folks out there who know what D40 and SD40 are. In fact, I can only think of one (not me cause I don't).
I am not sure re the part numbers, but when I ordered a kit for a one barrel years ago from 4x4 connection, all James asked was square or round sight glass. And the two one barrels I have--one with and one without the solenoid, are different internally. The linkage the step-up rod attaches to is different, IIRC, and there may be other differences. It's been a while since I've messed with them, but I remember that much.
good luck,
david
Good question. I could be completely wrong, but the major difference that i know about is the size of the glass window.
50% chance at this, but I believe the SD-40 is the larger window and the D-40 is the small window.
Dave
Dave
You got the 50% right. I was going to rebuild one of my carbs this weekend and am curious of what I can do with the parts on hand. I do not have the carb out of the truck, or even within 50 miles of me at the time, so I was trying to quench some curiosity. I have some of a carb kit for the 68-3/69 carbs. I also have a complete SD-40 kit, as well as an extra carb manufactured within a month of each other. The carb in question was placed on a vehicle during this time, but was manufactured earlier. The carb kits for its manufacturing date have been for an SD-40. The only kits for a D-40 I saw were only for one with the solenoid.
And with the simplicity of a 1 bbl., it is not getting sent out for rebuilding and tuning. However, I'd still love to know if one is more desirable than the other, and why. I'd also like to know about part compatibility. Maybe I should just scrap the forker and put something fuel injected in:grinpimp:
I noticed a couple differences...
I think the lower butterfly is brass on the earlier large site and alum. on the later small site with idle solenoid. Also, I think the later model had a power valve/piston?
