D$@m Injectors
Evening all. I just had a good used motor put in an LX I picked up, in addition to my ‘94 LC.
Right off the bat it experienced a misfire in 3 & 4. I figured maybe bad fuel or something along those lines. But wasn’t sure since it was just those two. I swapped plug wires and checked all that this afternoon, hoping I wouldn’t have to pull the manifold, but it made no difference.
I was looking back in there in preparation for the dreaded task and found out why 3 (and I assume 4) is misfiring… the injector is unplugged. Idk how it happened, but it’s a real bummer.
Unless… has anyone been able to get a hand in there and plug one in without taking it all apart, or does anyone see that even happening?
@mjosoba - I'm chasing a similar issue, have you been able to track down the source of the misfire yet?
Thanks,
Jeff
Hey, yes, I did. I took off the front portion of the manifold, instead of the entire thing. Thankfully. Got 3 & 4 plugged back in. Running like a top. Didn’t even need to replace the injectors.
