D/C front DS questions
Prescott Valley, AZ
I finally tracked down a shop that can weight balance the big tires.
Everyone out here has the standard size machine with the hood that can only fit a 35 or 37 - and even though everyone said DISCOUNT TIRE could and has done up to 42" tires - they now have a rule that they must do all tire break downs and air ups inside of a cage - so 35 is their max tire size.
I double checked each bolt with the torque wrench and each joint with a prybar. All seems solid, but I'm still going to end up replacing the bushings just in case.
I'll have the tires balanced tomorrow and the golf balls removed so I'll have a few days of driving around to see the results if any there.
I'm sure with the weird angle of the front DS at the Tcase that a DC driveshaft is probably needed.
Now my questions for those...
Is SLEE the only place to order these from? (just checking since I haven't heard of any other sources).
Is it possible to have the stock front DS converted into a DC shaft or is it better or cheaper just to replace it with a DC shaft?
I guess that panhard bar bolt tightened up fine?
One of the Toyota trucks has a double cardan driveshaft, which has the parts that can be used to fabricate one for the 80. If you want to search I believe Tools R Us has mentioned them, or I'm sure someone will reply here. IIRC it's as much or more to have one made as it is to buy one from Slee. I vaguely remember another vendor having one, but not sure on that.
-Spike
Yeah the spring perch bolt was still captured fine. I didn't know it was captured when I first asked about it - I just looked at it confused thinking it was an uncaptured bolt and couldn't comprehend how it was supposed to be tightened without removing the perch to access it.
Tomorrow I balance the tires and adjust the toe. Slees DC shaft is thicker tubing than stock, right?
Yup.
-Spike
Slee is prolly thie easiest place. You can go other routes but it may not be as direct bolt in. For example I did a 1310 DC joint and everything was fine until the flange that you bolt to the tc was to thick for the studs, had to send it back, have it machined. Slee's would be a nice bolt on fit.
Rear DS of late model Tundras, Tacos, etc has a DC joint with the correct flange pattern. If you can source one of those for cheap you can have a DS shop lop off your joint and weld on the DC joint (and balance it). It all depends on how cheap you get the shaft and the work done. When I got my DC getting a yard DS was ~$100 and the shop work was $200. I would have gone that route but got a Slee DC shaft used off here for $300.
