On my idling '75 2F, I can pull the plug wires from plug 5 or 6, or 5 AND 6, without any effect on the idle (which is amazingly smooth for a 4 cyl 2F). Pulling any other wire drops idle from 675 RPM to about 550-575. The exhaust smells rich. I need some ideas here, any help would be appreciated.
The details: Newly redone head, new plugs cap & wires, correct firing order, strong spark to all cylinders, timed at 10 deg BTDC, wet plugs at #5 & 6 (can't tell if it's fuel cause smells change at those temps), carbon on plugs 1-4 but not wet, drives OK like if all cylinders are working above idle, all plugs gapped at .039.
