cutting the tie rod ends?
Boise ID
I need to shorten my tie rod down to 46 1/4". I ran the ends till they bottomed out and still had to go another inch.
If I cut the tie rod 1/2" on each side and then cut 3/8 off the end of the threaded end of the rod ends I will get to where I need to be.
Is there an issue w/ cutting the tie rod ends down?
Are you using new Toyota components?
I do not understand if you have the correct tie rod for a 40 series, why you would have to shorten it...
I am using the orig. tie rod. I have a set of arms the I had W. Harold at over the hill 4x4 bend up for me for a SOA app. W/ the correct toe (?) the tie rod ends now sit at 46 1/4".
Center to center on the tire, the front is 1/4 shorter than the back. Correct?
Typically when W bends these he installs them right on the left and the left on the right. This provides better clearance for larger tires. So now the arms are pointing inward a bit vrs outward as OE. Most cut the OE tie rod in the center and sleeve, rosette weld, and weld the ends of the sleeve. (Got’a know what you are doing with the welder, Steering is just about the #1 safety thing you want done right. ) If you cant do it just ask W/ to send you a TR cut down.
Other wise custom built tie rod, but that will cost more than your arm mods did.
Acumen angle: No idea, I drove W’ arms for two years then recently switched to Alpo arms. (Built new tie rods so I swapped arms) W/ 35” SX Swampers it dives the same. Maybe with a different set of tires I might have noticed the difference.
Personly I would not reduce the amount of theads engaged in the tie rod. I am sure normal driving it would be fine, but hit a curb hard or some hard off road might weaken something. Of course it would then fail at 50mph turning to get onto the HW.
TRE’s do fail I had an OE Rod Snap at Moab, fortunately going slow is when if finally failed.
Mark
I have cut the rod 1/2 on each side and was going to cut the tie rod ends just under half on each side.
This will engage almost twice the amount of thread as it was stock.
helocat, I placed left on left and right on right. I am running 35/12.5 and did run into some clearance issues w/ the tire. I plan on getting 2" BS rims so that will take care of that. For now I am running a 1/4 spacer to clear the tie rod end.
I will not have much adjustment to shorten the rod. W/ what I am doing It will be set for 46 inches with all thread engaged.
Any issues w/ this?
I got W's arms when I went SOA and I had to shorten my tie rods and drag link (with saginaw conversion).
What I did was I cut it down the center and took off what I needed, then I inserted a steel rod inside of it, then I over sleeve it with some tubing (I think it's about 3/8" or maybe smaller.. not sure), drill holls on the tube before oversleeving though, then welded the ends as well as inside the holes.
That thing is not breaking I think I'm bending the arms before i break the rods. :D
- Good Luck.
- Rico.
$80 and that included shipping back to me. I wouldn't hesitate to have him do them again. He cleaned them up and sprayed them black.
I shiped them on a Thursday and the arms were on my front door on Thuesday. I was thinking that it would take a week or two. Nice guy to work with. He was leary and wanted to know that it was a trail only machine.
I did the same thing, but I did my own bend, and "normalized" the steel. I cut my tie rod in the center and then rewelded and welded a sleeve over the cut. Im sure that the welded area is stronger than the rest of the tie rod. works well, but it looks a little funny. probably quicker and easier than trying to retap.
I finished my tie rod. I did cut both ends 1/2 inch and cut approx. the same off both ends of the tie rod ends. The threads are almost fully engaged with the toe in set and -1/4. I can adjust in a little but not much. There is almost 2" of thread engaged on both ends.
How would cutting the tie rod end down change the ackerman (sp)?
phly nothing about the tie rod or ends changes ackerman, that angle is based solely on the steering arm angle.
also just to back you up, nothing is wrong with cutting down the tie rods. no effect, no harm, no safety margin.
Thanks guys. Everything is done now. I do have a spare tie rod. I think I am going to cut it down in the middle like previously posted and sleave the inside. Just to have a spare.
