Cutting in and out?
PA
Sorry if there is a lot about this but really didn't know what to search for. The problem I have is, it starts fine idles fine but when I give it gas it goes up to about 2500rpms then dies and drops to idle. If I keep my foot on the gas (in the same spot) it goes up to 2500rpm drops to about 800-1000rpms then goes up to 2500 then drops. On and on and on. Wonder if someone might know what it could be? I checked for any hoses that were off or damaged and nothing. Thought maybe MFAS but not sure. And help would be appreciated.
That sounds like it might be fuel delivery.
The fuel filter is a pig to change, but if you haven't done it in a few years...
There is a fuel pressure regulator that dumps excess fuel back to the tank. It might be failing. It's on the front of the fuel injector rail, a bit behind the distributor. It has a vacuum line on it, and a line that goes back to the tank. I'd disconnect the return line and see if fuel is being sent back toward the tank.
Your fuel pump has two modes, through a resistor for low pressure, and full 12V for high pressure. The resistor is on the passenger side fender wall, and the relay is on the driver's side fender wall.
I haven't changed the fuel filter for a while. Have been dreading it. Will look at the things you mentioned. Thanks for your help!
Might also try checking your rubber air hose from the top of the engine to the air filter can. Mine was cracked and the engine shifted just enough at certain RPMS that it did just that just like what you describe... I found a crack in the accordion folds.. that was not obvious until I had it out and in my hands to pull it and twist it and inspect it closely
I replaced the hose and the problem went away.. Take it off and check it.. If cracked order a new one with nice new soft rubber and use duct tape in the meantime to patch the old one for a few days till you get a new one! ;) Or just duct tape it and go full redneck! :hillbilly:
