Cup Holder Modifica-she-on
Colorado
My wife and I finally took our '96 Cruiser out on it's maiden voyage for our 10th anniversary this month after purchasing it in June. We were very anxious to take it on a road trip but couldn't because the front axle looked like it had never been serviced, the FHH was leaking along with another heater hose that exits the heater core on the firewall. It only had one alternator fan belt left (which was wrapped around the idler arm pulley) and it was about to snap the second belt from the looks of it. It also had car quest auto parts radiator hoses on it which didn't look like they fit right. Bad Land Cruiser owner! :mad: After many calls to CDan (who I think knows more about the 80 series Land Cruiser than anyone on the planet, including the engineers who designed it), I started collecting parts to base line it the best I could before taking it out on its first shakedown run. So...new Firestone Destination M/Ts 285/75 R16 tires, running board removal, birfield rebuild, (hi temp heater hose/radiator hose replacement, Radiator flush and replace the green coolant (with, yes...Toyota red), hi temp PFHH hose, alternator belts, A/C belt, air filter, oil/filter, transfluid flush, transfer case, rear diff oil change, and a new windshield (to replace the leaking one that the PO had installed by earl and his other brother earl) later...we were ready to roll! Hopefully I haven't forgotten anything.
Anyway...on to the reason for this mod. The new Toyota Taco's (four door) have THIRTEEN friggen cup holders in them! I hopped in a friends with my 32oz Nalgene and it fit in the main, self adjusting cup holder. I hop into my once almost $40,000 Land Cruiser with not one friggen place to put it besides on the seat or floor behind the console to fly around. :crybaby: On our trip it worked out ok because we had enough stuff in the back to help hold two of them in place and it worked out ok. Once all the gear is gone, then they fly all over the place. :confused:
After reading the mods for the cupholders on the mud forum I went to the local NAPA auto parts store hoping to find a solution. Didn't really see anything that would work until I looked a this picture, then it hit me...:idea:
Home Depot
Since a picture is worth a thousand words I'll mostly post pics instead of the boring commentary. From what I can tell, you guys on here are :banana::banana::banana::banana::banana: mechanics so you'll get the gist.
I just needed a piece of "T" shaped steel strong enough to hold a bend and about 64 OZ of water which is almost 4lbs. I remembered that Home Depot sells the "T" shaped brackets used for wood framing which I had used to build a double gate on the side of my house. The cup holder came from NAPA..console twin spill master.
Steel Fabricat-she-on
Using a hand grinder with a thin wheel, I trimed the steel to fit the cup holder on the bottom. I also picked up some #10 panhead and flat hardware from Home Depot to maount the cupholder to the steel bracket. The intention of the bracket is to keep the cup holder up of off the floot out of the way of the rear heater vent and out of the way of the rear floormat since I still plan on using the rear seats for passengers occasionally.
More steel fabrica-she-on
Holding the brackets in place I marked the holes to be drilled to mount the cup holder. I used the flat head screws on the outside holes to make sure they wouldn't interfere with the adjustments on the cup holder. I test fit the holder and cut off the excess on the bolts so they wouldn't snag anything.
Even more fabrica-she-on
Since I am anal...I used a protractor to measure the angle on the back of the console so I would have some idea of how much bend to put on the bracket.
A little more fabrica-she-on, then on to paint...
I marked where to cut the bracket then drill three holes where the bracket mounts to the console...
Now on to paint...no, not yet
I test fit the bracket to the console, still in place, to make sure that it was centered between the seats and to make sure the height would be correct so the console would still open with drinks in the holder... mark with a pencil so it will clean up. I tweeked the bracket a little to try and conform it to the curve on the console so it would sit straight.
ready to Paint???
The last pic shows the console removed to mount the bracket to the console. I went with three holes for a couple of reasons. The bottom hole allowed the bracket to be leveled, and the top two hold the bracket flush to the console and also counter against any weight with only one drink in on either side the cup holder. Now for paint then assembly.
Almost done
The only other thing I would like to do is find some sort of a rubber strip about an inch wide that can be glued or stuck on the inside of the holder to help grip the bottles a little more so they don't jump out of the holder. So far it seems really solid. The only other change I would of made is to maybe use some sort of light lock tight on the threads since I didn't use any lock washers on anything.
Hopefully this sparks some ideas on the pesky (lack of) cup holder problem on our rigs...and hopefully this brings me up to a :banana::banana: mechanic status!!
Cool idea.
Can you still fold the rear seats, without hitting the cup holder?
Thanks...that thought came to me after I did the mod..:doh: I have all of the seats out right now...I'll let you know...I think it will be ok because the front seats kind of block the cup holder. Here are a few other pics from the side with the drivers seat all the way forward. See how the passenger seat sits back almost past the cup holder.
very nice work, looks like it came from the factory that way.
I didn't look too hard...I was hoping to find one that was tan colored...no luck. I checked a couple of other auto parts stores but all they had was black. I'm so anal that if I see a tan one, I'll probably buy it and swap it out and find another home for this one...or take it back.
Yeah, it looks like the only problem would be the headrests, and they're parallel with the front head rests, so unless you have a couple of really tall drinks in the cup holder, I don't think folding the seats down would be a problem.
Thanks BTW...you just sparked another idea of replacing the one on the side using a single, similiar to what I did on the back. Hmmmnnnn...wonder if another double will fit over there???? FOUR cup holders!!!
just checked...not gonna happen...
the four cup holders that is...
"it's getting tight in here"...from the movie The Abyss...
Great work on the cupholder, I am going to make one for mine! As for the 4 cup holders I have always wondered why my FJ62 had a double cupholder in the same spot on the side of the console where the FJ80 only has a single? Has anyone tried to mount the 62 cupholder on the 80 console? I am in the process of a bit of engine and interior restoration so might try to see if that will work as well.
Rusty
