Crush gaskets same for rear diff and t case?
Manitoba
Simply dunno if they are the same I couldn't find any info, I did order 6 of the crush gaskets that fit the rear and front diff for sure but wasn't knowing if they fit the t case. Thanks
Transfer case gasket is solid aluminum: 90430-A0003
Diff gasket is folded steel: 12157-10010
Transmission drain gasket is folded steel: 35178-30010
Oil drain bolt gasket is reinforced fiber: 90430-12031
Ah ok thanks. I definitely ordered only the front and rear diff gaskets not knowing the t case was different (oddly enough the description on toyota.ca said t case as well) but I'll just re use the old ones then. Thanks! Big help man
