Cruiser Smells Funny
I recently did the Whipsaw trail up in BC and got out at a lake to check oil, water etc... When I popped the hood there was a strange leaking sound coming from the charcoal canister. I went to the back, cracked the cap off the fuel filler and for 5 solid minutes my gas tank vented out vapor.
Since this just happened last week I haven't gotten around to pulling the canister, but I think the plugged vapor line is the ticket on that one.
For the time being I just left the gas cap cracked a little open and it's taken that smell away as well as the over-pressurization. It also helped a ton in the drivability.
Plugs and air filter, 3months
Fuel filter, less than a year.
So. What conditions have you driven it in since then or rather between the filter changes and the smell. I think mine was smelling similarly and I had just cleaned my filter a week or two before our trip.
I still like the idea of the plugged line off the filter. Have you checked that out or are your mitts just too darn big to fit in there? :D
Butch (the guy who thought he blew his head gasket when he really didn't although it probably saved my life)
Jay,
Mine has gone away. Yesterday I had a fully vapor free fill up. I talked to Robbie about this at the Cruiser Rallye. He said the EGR valve will only open under certain conditions. If you are running hard on the throttle and it is hot out it won't open. Thus it creates the pressure which causes the whoosh. Also check your tank fittings. When i got home my filler tube was loose too. Really I don't think that had anything to do with the pressure. I think it was the high Idaho heat and then in Colorado being on the gas all the time.
PM I'm curious as to when you are going to the Boulders. Next Sat. NW Cruisers is doing 2HD and LT. If you didn't get enough of the rocks in CO this would be a fun one.
I have this gas smell after I stop the car and while idling in traffic with the windows down. Usually smell it on the driver side at the rear passenger door. Not coming from the gas cap, and I havn't cracked the cap for any reason either.
Could anyone snap a picture of the line where it goes under the truck and connects to the rail? There are a lot of lines on the drawings that look right, but not a clear image of what I am looking for when I go under the truck. I love working on the truck, not fidding with things that I shouldn't.
Glad to hear this could be a minor repair, it's only been happening for a couple of weeks (just got stupid hot here in Georgia, but cooling off now).
Jay,
Were you ever able to resolve this?
Mine recently started to smell (rotten egg sulfur), but I've been driving around with an o2 sensor that needs to be replaced...just arrived today, so I'll be putting new ones in this weekend if all goes well.
When my o2's were going bad there was an odd smell, What about the charcoal*sp canister or something plugged/leaking on the fuel return?
Good luck
when the o2 sensor in my 4Runner went south the truck would smell like sulfur/ rotten eggs when giving it any significant gas. It was particularly noticeable when the back window was rolled down because it was definitely coming from the exhaust tip.
The smell went away when the weather cooled off. I expect it to return, so I will need to resume diagnosing it then. I did find cracks in the lid of the canister and signs of a previous attempt at patching with silicone, unless thats factory.
I still suspect I have a fuelish issue going on between the weird exhaust smell, sooting, and vapor smell when hot. Maybe it's all related, but I havn't been able to clear it up yet.
Jay
heat shield
I had a new heat sheild installed on the catalytic converter , and it still smell pretty ripe, then goes away when it cools off.
