Thursday I decided that it was time to finish the lift on my 80. While it was in the garage I decided to do everything else I had been putting off. Here is how it all began.
First I put a window unit AC in the garage (it was 105* with plenty of humidity at 1:00 yesterday afternoon!)
List of things done to the Cruiser:
Rear shocks - Can't find OME "L" shocks so I put on some Pro Comps until the OME's come in
Tried to adjust the LSPV, but only succeded in busting the bolts that hold it on
Bedlined one side of the truck (other side will be done tomorrow)
Replaced spark plugs
Replaced plug wires, cap and rotor
New fuel filter
Replaced PHH
Stainless extended brake lines
Replaced the radiator
Oli Change
Bled brakes
Thoughts on the job
The PHH really wasn't that bad, in fact, it was actually pretty easy.
The stainless brake lines were a ***** to get tight enough to where there were no leaks
Whose bright idea was it to put the fuel filter there?
Why did Toyota think they needed the radiator bolted in like that "WTF?" pull the battery AND the grill just to replace the radiator????
I wonder how long the LSPY will stay in place with just rust holding it on??
Anyway, 10 hours in the garage is still better than being at work!
New fuel filter
Replaced PHH
Oli Change
Bled brakes
Thoughts on the job
