Cruise Cut....
Lil Rhody
Driving to work Saturday...on the highway with the truck in cruise...and the vehicle comes out of cruise. No brake lights on the dash, the cruise light stays on, my feet no where near the brake pedal. There was a little hiccup in the engine revs as it happened. The following day the same thing, except it was nice and smooth, almost as if I just pushed the cruise button. Any thoughts ? ...hand brake adjustment? I read through the cruise control thread and it seemed like whenever others lost their cruise, the dash cruise light also went out.
John
there is a common problem and the cruise light usually blinks and then goes out when it happens.
The fix is to pop off the cover above the cruise control actuator and cycles the arm by hand a few times, I had this happen for the first time on a recent 6 hour trip, I had not been using the cruise much for the proceeding few months, not looking forward to that long drive without cruise I tried that and problem solved.
I would try that first, if it comes back look to the FSM for troubleshooting.
Common issue is the brake reservoir level sensor in the cap. When they fail they tend to go intermittant and will very dimly light the BRAKE lamp on the dash. In daylight you may not see it at all.
Replace the cap with a new OEM one.
Another possibility is a faulty door switch. Mine was cutting out whenever I would go around a corner and the door was loose enough to allow the door ajar light to flicker. I adjusted the strike plates and cleaned the door switch contacts, all is now good.
