Cruise Control issue -
Occasionally on my 96 Cruiser I'll turn on the cruise control and the cruise control light on the dash will blink a couple of times and then turn off. All attempts to get it activated, to light the lamp on the dash after this fail as long as the car is running. Obviously, the cruise control logic has detected a problem and shuts down. I now that if I stop and turn the Cruiser off and restart I can usually get the cruise control to come on and use the cruise control through out the rest of the trip.
Is someting related to the cruise control logic/sensors getting ready to fail?:rolleyes:
Thanks in advance,
Wingo
You are not alone on this, I have had this happen on several instances. I have not been able to track this down and really don't know where to start.
I hope someone can shead some light on this.
That seems like it may take care of the problem......I guess I'll find out.
I did have he codes checked and the only code that came up was for the O2 sensors which will get replaced shortly.
It happens very randomly which is what has me puzzled.
If you pulled engine codes, you didn't get the CC codes. The CC codes are pulled from a different port.
This thread has some good information, for both pulling the codes and performing some troubleshooting actions.
https://forum.ih8mud.com/80-series-tech/5600-cruise-control.html
The FSM should have a section on Cruise Control and how to pull codes from it...
My CC just doesn't work. I pulled the code and found that it was the electric speed sensor (mechanical speedo).
I'm thinking we've discussed this before and you stated you're just too cheap to buy a new one??
Bingo. :lol: :hillbilly:
Besides, it's not that I'm cheap, it's just that I won't ever use it.
