Hello, may be one of you guys can help me out here. The threads have been really helpful but I am running out of ideas as to what to do with my curise control problem. I have 91 with 200k+ miles on it. The cruiser control does light up when you turn it on but it does not set. I read just about all the threads that talks about the cruiser control issue in this forum (couple of times up and down).
Here is what I have done so far.
1. Replaced stoplight switch
2. Cycled the actuator 8-10 times. Cleaned and looked inside. Looks clean.
3. Check the speed sensor by the transfer case. It looks clean but cleaned some more.
4. Check the brake fluid level switch and filled to make sure it is not it.
4. I did the dignostic with cruise control and it passes. No code.
5. I ran the test per instruction below.
A. Turn the ignition switch on.
B. Turn the control switch to SET/Coast position, and keep it there.
C.Push the main switch ON.
D.check that the indicator light "CRUISE" lights-up in the
combination meter.
E.Turn the SET/Coast switch off
F.Meet the conditions listed in the table below.
G. Read the diagnostic code on the cruise control indicator light.
#1 Turn the control switch to SET/Coast position
there should be two flashes and then a second break and then two
flashes, then break then two flashes etc. If you get the flashes your
SET/Coast circuit is normal.
#2 Turn the control switch to RES/ACC possition.
this time you get a pause and three flashes, repeated again and
again. if you get the three flashes RES/ACC circuit is ok.
#3 Each switch is turned on
a. Control switch to CANCEL.
b. Stop light switch, (step on brake)
c. parking brake switch. ( pull up parking brake)
d.Neutral start switch. ( put in neutral)
if when you test each of the 4 cancel switches you DO NOT get any
flashes then those switchs are normal.
THIS IS YOU, And now you have to leave the driveway.
#4 Two parts for speed sensor
A. Drive at 25mph or below. if there are NO flashes sensor is normal.
b. Drive at 25mph or over. you should get constant steady blinking.
if she blinks sensor is ok.
#1 passes. I get the two flashes followed by break.
#2 failes. I get five slow flashes and it turns itself off. I cannot not turn on the cruise control until I cycle the ignition. I have looked at all the code there is and this five slow flash is no where to be found.
What does #2 failure mean?
Thanks in advance.
BTW, it started to rain. It is a light show outside with thunder and lightening. Seattle weather knows that kid's school is starting tomorrow. Nice...
Sung
combination meter.
Thanks in advance.
Sung
