Cruise Control HDJ81
Is it my imagination or do all 81's have a lousy cruise control. I've driven three so far and they all sucked, kicking out and hard to set. Anyhow, does anyone have a recommendation on an aftermarket one to put in or a tip on how to adjust it if even possible inlcuding the govenor.
cheers,
Greg
My cruise works great. No issues.
Easy to set, and rarely kicks out.
Maybe twice in 6 months.
Happens when hit a hard bump on the highway and my break pedal jiggles a little.
If yours is kicking out, maybe your brake pedal is loose.
That would cause it to kick out.
As for setting issues, I am not sure what you mean.
Could you elaborate?
As far as the govener. I know its set to 109kph, which is fine for me.
Especially because with my tires 109kph is about 117kph.
No way to adjust it as far as I know.
I am sure you could adjust it, I just don't know how.
Cheers,
Nick
thanks, I'll check my brake pedal. As for setting I mean when I attempt to set it at whatever speed it just won't engage.
cheers,
Greg
I've had the same experience as Nick. No problems with my cruise at all.
cheers,
Greg
Might be a result of a loose brake pedal.
I would start there.
Cheers,
Nick
I find with mine that you have to hold the stick back for a few seconds for it to engage - as opposed to just flicking it.
