Crossmember paint code
RyanTomorrow
Livin the livin.
Belmont, MA
I KNOW this is a stupid question, but honestly I've tried searching the answer and haven't found a straight reply:
What paint should i use to repaint my rear crossmember?
(PO had a bunch of bumperstickers that left weird fading patterns)
:zilla:
I would like to know what paint to use too.
Also the best paint for grills and any metal parts exposed to the elements.
It's the same paint as the chassis, so go find some chassis paint at an automotive finish store. It's going to look newly painted unless you buy a lighter shade of chassis paint and add a flattener to it for a semi gloss/satin finish. Your best bet would be to carefully remove the end caps and clean with a mild soapy water. Then use some wax, tar, grease and adhesive remover/prepsol to clean the surface of contaminants. Then go buy some 800,1000,1500, 2000 grit wet/dry sand paper and a sanding block. Get a bucket of warm lightly soapy water to soak the paper in and a sponge to apply water while sanding. With very little pressure lightly sand the whole area working your way through the grits. Wipe it clean and let it dry between passes in order to see if the fading goes away. Then using a buffer or hand buffing, apply rubbing compound to compound it out to a even and semi polished finish. Then go to the automotive finish store and get a can of satin clear and spray it in 2 light coats waiting for it to flash at least 10 minutes or manufacturers suggested flash time between coats. Then 1-2 medium wet coats letting it flash for longer between coats. That should fix your issue and give it the appropriate fisnish OP. Otherwise if you don't mind a noticeably newer shiney rear crossmember than get some black beauty or rust bullet or POR15. Any of these can be put in an aerosol can at a automotive finish supply store if you don't have the gear to shoot paint.
As far as grills and such, @82much it's not clear what you're asking. If you want paint for the grill which is plastic, you can use whatever automotive paint you would like more or less. You just have to prep it as above by cleaning, using a pre-solvent and then scuffing with a red scotchbrite. Then wipe clean and wipe with a tac-cloth and spray with an adhesion promotor for plastics....duplicolor makes one you can find at autozone and probably other stores. Then just follow directions on the can of promotor and the can of paint. As far as metal goes. Clean it, prep-sol it, remove or treat any rust, re prep-sol it. Tac-cloth it, Etch prime it, fill prime it, sand it lightly, re-tac it,surface prime it and shoot it with paint. Clear coat it and don't wax it or get silicone on it for at least 30 days or manufacturers specified time period.
@LandCruisinMy93 hell, that's a far more comprehensive answer than expected, thanks! Really appreciate it.
