Cross member to stop frame flex??
Lakewood, CO.
Cross member, stop some frame flex??
What do people think of this cross member, it should stop alot of frame flex?
I ran 3/8" thick plates down both sides of the frame underneath(sp?).
Then I drilled 4 9/16" holes on each side, to use massive 9/16" bolts.
All of the square tubing is 3/16" thick.
To bad I don`t have the Atlas anymore.
Flame away.
You can remove a lot more frame flex by welding the inner frame C to the outer frame C
If you want to remove frame flex, yep..
When I replaced my frame, I had a welder friend stitch 4" where every rivet was on the replacement. It turned out alright. we also boxed the frame to the rear spring mounts, and I think that helped as well.
I just finished welding mine all the way. The welds I had done before caused cracks at the ends of the welds. Needs to be fully welded.
