Critique my build list for axle upgrades
I'd love some sort of exterior bolt replacement kit. I've snapped several off. So far I just go to Ace and buy the grade 8 zinc coated bolts as needed
for the body mounts? i hadnt even thought about that, probably way cheaper.
Absolutely swap out the rear wheel bearings while you're in there. I have the special press fixture if you need to borrow one.
Eimkeith PCK should go on while the rear axle is out.
Stainless extended rear brake lines while it's apart.
I'd also pick up some front spindle gussets if you think you may beat on them.
If you really want to go big, take a look at the JD fab kit for the LCA mounts.
I also replaced the Rear Driveshaft on my 06 4R. HUGE difference in the way the truck felt, no more clunk coming to a stop or taking off. If your truck does that, I highly recommend tossing that in. It was only ~$300 from Toyota.
-Rob
I get hardware all the time from my local farm and home store. They sell it by the pound - metric and SAE/standard. So, my GX has lots of 13 and 15 mm headed-bolts on it, instead of 12 mm and 14 mm :).
-Rob
ill get some ordered up, im having mountain goat offroad in ida do the internal axle work. the price and timing to have expedition vehicle outfitters do it was prohibitive. i have extended brake lines and newer gx460 driveshafts. ive gotten the "going fast" out of my system for the most part, for low speed rock work do you think the spindles are worth it?
I bent one of my spindles on a random rock cruising across Black Bear pass a couple years ago. They are pretty weak from the factory. I'm not sure what needs to be done to use a stock swaybar with the gussets though.
-Rob
-Rob
oh my front sway hasnt been on since the week i got it, thats not an issue lol. my truck is a lot heavier than stock, good call on the spindle gussets.
Ugh, I'm supposed to do black bear pass in July. You think a 1" eibach coilover lift with 32" tires will make it? Else I'll take the coilover converted JK w/37's
Yep. For sure. I did it with a Dobinsons 2” lift and 32s.
I did a lot of trails in the San Juans stock height on 32s in 2021, and then more of them in 33s in 2024. Black Bear was closed in late 2024 due to a mudslide. The only place I could not have gone with my original setup were to the base of the wall on Poughkeepsie Gulch and some side trails we did coming west off Engineer Pass. You will, however, definitely drag at that height, so I would suggest some good skids. And, it's possible you'll gouge or rip off the rear bumper due to the kind of crummy stock departure angle.
FYI, wheeling is much easier and comfier on 33s.
Elocker going into the 8.2
Ok axle is finally done, and now onto installing everything on the truck. budget is holding up well, but the teardown on the front end i expect to find parts (im assuming LCA bushings) that need replacing.
OK project is done, some small stuff to take care of. picked it up last week, got it aligned and have been enjoying driving it. I didn't expect the 3.91s to make a big difference vs the 3.73 but you can absolutely feel it. drove my dads stock gx470 with stock size tires then I drove mine, and really the shift points and acceleration feels almost identical (I am on 285/70r17) will be trying out the locker this weekend but confirmed its working. losing the rear sway took some time to get used to but it's not too bad with the heavier springs i have in the rear. the body mount bushings were definitely shot, body sits about .5-.8' higher now.
overall, I was able to stick to my budget. a few unplanned things popped in, I got great deals on the labor and some of the more expensive parts. whole process took about 2 months, but if you were willing to pay more in labor, and had all the random parts ready ahead of time this would probably be doable in a weekend with a lift according to my installer (across the tracks outfitters in lake odessa michigan put everything on the truck, mountain goat offroad in ida michigan did the axle work) also shoutout to TRE 4x4 usa for the deals on the locker, and petes auto parts for the well priced axle, diff and steering rack.
