- Joined
- Oct 20, 2011
- Threads
- 9
- Messages
- 37
hey guys. got some current problems. Ive been testing things with my multimeter trying to make sense of it all. just about everything to do with ignition has stoped working. here is a list of things that arent working:
turn signals
diesel marker
temperature reader
battery light
4x4 light
Oil pressure light
things that are working
headlights
hazard lights
starter
I dodnt check the brake lights, don think it really matters anyway.....
Things I've done:
checked all fuses, all fine, replaced about half of them because i had some laying around
disembelled the ignition switch and cleaned it with electric cleaner. i fixed my headlights at least which wouldnt go low beam. it wasnt the problem. i then noted that electricity was flowing in and back out of ignition as the key was turning.
flows getting from the signal switch to the flasher. flows going from the ignition switch to the signal switch as well. 12 vs are going to the ignition switch.
If i cant figure it out tommorow before midday, im taking it to the electromechanic (2 hour drive). but Im sure I can find it myself.
there must be some place all this wiring converges. maybe a relay or something. but where, i dont know. ive followed cables everywhere looking for anything obvious.
any advice would be greatly appreciated. Im going to look as some wiring diagrams and meditate on the flow of current
turn signals
diesel marker
temperature reader
battery light
4x4 light
Oil pressure light
headlights
hazard lights
starter
Things I've done:
