Crazy electrical ghost - help!
Hello! My '92 landcruiser has electrical issues. Here is the whole story.
1. When I use the blinkers I hear static coming through the left rear door radio speaker. If I leave the blinkers on for any extended period they begin to both glow at the same time and eventually blow the fuse.
2. Also when I use the electric window (from drivers panel) for that same door I hear the static through that speaker.
3. Also when I put the car in reverse I hear static and both blinkers come on. This happens when I push the rear defrost as well.
4. Hazard switch stopped working.
5. rear window wiper will not shut off. (I have diconnected it and the relay box that sits next to it continully clicks irradically.)
6. Fuel gauge is irradic.
7. tail lights flicker.
What I have done:
1. Checked all bulbs. Changed both brake light bulbs (they where burned out)
2. replaced defrost fuse (burned) and blinker fuse (burned)
3. Disconnected the trailer light control box. (this was my first suspect.)
4. Cleaned the main ground from battery to the chassis.
Any advise would be great!
THanks!
Do you have an aftermarket or Toyota Trailer wire Harness. I had something very similar some time ago. I unplugged the blackbox in the rear passenger side of the LC and that solved my problem. You have a 92 and mine was a 97 so not sure if they are similar, but worth a look.
Is the radio factory or aftermarket? Did you check the body grounds?
how long have you had it? are you sure it is not a flood vehicle?
I've had it for six years...this happened first last spring as well and it I chased it for a couple of weeks and then magically it went away and stayed away until last week.
Not sure about earlier models but the 96 has a number of body grounds that I know of; drivers and passenger side kick panel, rear sill over the spare tire and under the console as well as 3 under the hood. They are at either front corners and at the DS of the engine.
Toyota Techdoc web site has a document for download that shows where they are.
You have so many strange and seemingly unrelated problems that I would suspect that some rodents have been chewing on your harness. Check the part of the harness that contains all the wires for the wonky devices.
Well, now my blinkers are blowing fuses almost as soon as I put them on...I dont think I have rodents(!) I drive it everyday and have never seen any trace of droppings or nesting materials...I was hopeing that there was a controller box or brain that controlled these devices that people would point to. Are the blinkers controled by a "regular" blinker relay or??
Thanks for any help, this is driving me CRAZY!!:)
You aren't going to like this.
I think the common link here is under the dash or the wiring in side the steering wheel/turn signal area. U will have to do some looking at the wires under the dash for abrasion . Also, dismantle the turn signal switch and check for worn out switch contacts. Something is telling me that these contacts are worn and creating an intermittent short.
This kind of stuff is a bitch to trouble shoot.
