ratios:
first gear x t-case1 low x t-case2 low x ring/pinion = crawl
6.5 x 2.4 x 2.313 x 4.11 = 148.3:1
(SM465 x minitruck range x 72 FJ40 t-case x stock diffs)
...and yeah, I'm guessing on the mini low...can't recall offhand...
also see the tech links, right column under Misc at the bottom for the calculators link...I think there's something in there for autocalculating..
That's a myth. A torque converter at idle won't drive through your brakes.
However, when my throttle tightens up due to the way the PO engineered the linkage-type throttle on my 55, it'll drive right through the 4 wheel discs. that's with 4.10s and 4:1 low range.
You've got nothing to worry about anyway. a 3.0L will explode before it drives through your brakes.![]()
usually im staring at pig ass when im wheeling![]()
that's like saying "ford is better than chevy". it's such a general and random statement.
it all depends on the stall speed of the converter. a stock stall or low stall converter will definetly try to drive thru the brakes. you'll want something with a stall speed of 1500-1800 or more to avoid that situation.
