Crankshaft replacement
In the Rat Hole
OK, here is the problem, One of our cruiser pack members is in the process of re-installing a 10~10 crank in a 1F cruiser. In the torquing down of the caps the crank wants to bind-up. The bearings are 10~10 also. The clearance range indicator gives us these #s #1-.001 #2-.0015 #3-.0015 #4-.001 journal readings. According to the fsm they are a little tight, but not much, I guess my next question is, do the shims between the block and the caps stay the same? or thicker? they are .20 the ones that came in it. Any veiw points or coments? Thanks, Fuzz:confused:
Well, to ad more info to the problem at hand. The crank and bearings came as a kit from a major cruiser supplier on the left coast of the USA.(no names mentioned at this time) After a long chat as to the problem over the phone, no grief was relieved. Planning on taking the mess to a local machine shop for futher investigation.
Clearance range indicator as you put it.... plastigage? are you using the correct diameter for this type application? .025/.076 green in color? your result readings are a little wacko... you make no mention of thrust clearances.. what are they? as for the .20 shims.. replace them in the correct positions as they were removed.... they are only there for line-bore purposes....
Yes, green plastigage is used, as for thrust? I dunno:confused: may have been over looked:o will check on it
OK, best I can tell the thrust clearance is .000 as in none. And why not use shims between block and caps? We made some from a beer can and installed them as a test, and the crank turned smoothly. Thanks
By adding clearance between block and caps? you are increasing the size of the main bore.. the bearing shell halves will not make end to end contact.. that is not good... you're not dealing with block,cap, bearing clearance issues here... keep the thought on bearing to crank clearance..the low or lack-of numbers(.000) in the thrust?... tells me the thrust area of the bearing is 10 over as well as the journal size and the crank thrust dimensions must be standard... the only way to cure the problem is to machine crank thrust area to make a proper fit or replace the brg. with one that has the correct dimensions.... get the thrust issue resolved and do another plastigage squoosh test...
Whatever you do get this figured out before I do my "F"..... I may just take it to a machine shop.....The Beer can shims are classic.....I have lots of those around....
OK, dropped off the crank at the machine shop for inspection. The guy didn't have time to "jack" with it at this time, but from I told him about the thrust, he agreed something is foul in this area. Should get results tomorrow. Thanks ,Fuzz
Hey! grant5127, My cruiser amigo picked-up the crank today. :) The machine shop dude said the thrust area on the crank was indeed standard measure. He believes when we installed it and did the torque down thing,(using the fatter bearings), we actually were bending it bit and that's the reason for the sporadic squish test readings.( not to mention, it wouldn't turn) :frown: Just reinstalled it, torqued it down, and all readings are .002 Turns slicker than snot. Copacetic! Life is GOOD! (well for now) Thanks, Fuzz:beer:
I sincerely hope , your crank and rod machinist are not one in the same........
