Crank Pulley with Supercharger
Orlando, Florida
In the middle of the rebuild on my '95 which has the TRD supercharger. Some witness marks on the timing and oil pump cover that indicate the crank pulley / harmonic balancer has seen better days.
Before I order a new pulley, is there a better option to use compared to the standard OEM pulley? I know when Toyota released the Supercharger kit it was designed around what existed on the original engine so just checking if there is a pulley out there that is better suited to supercharger application.
I just got a new standard pulley from Toyota. I notice rockauto had a "sports model" available but i have no idea what that means or if it would be better.
Sounds good. I’ll check out that “high performance unit” and thanks for your response.
