Cost to re-gear.
Phil,
You have 35 on the 100 right? We are thinking about uping the tires on the 100 to 35, but we still need to pull a full load plus trailer. Will this be a problem?
Phil,
I have 35's on the 80
I have 33's on the '99 100
I had 35's on the 06 100, HERE is my towing review but keep in mind it had a VVTi motor ~40hp more then pre 05's 100 series.
If I wanted American junk, would own a heep!:o:lol:
Lol, I feel the same, but a good US Gear just has a better quality steel if they are available for your FJ?, unless you get Toyota quality gears, but most of the aftermarket crap is poor steel quality. Just pointing out a fact, not knocking any other diff builder, as I'm pretty sure my Blazer buddies have found Zuk on CK5 and are very happy with his work, but I was offering up another reputable builder who AZ Diff specialists had hired on when they had a large work load. Some "Reputable" shops use inferior gears and cheap bearings, causing problems down the road. He doesn't stop working seasonally, and does quality work at a fair price (hard to find anywhere these days).
$150 for setup with regular crush spacer +$50 for solid spacer
$220-250 gear set
$180-Bearing kit (all bearing sets are Koyo or Timken)
(602)863-0321 Steve @ A-1 Differential
For anyone thats interested.
$220-250 gear set
MC,
Is that $580 plus gears? That would be about half of what I'm seeing elsewhere! What I'm finding is around $650 plus the gears and install kits.
That is gears, bearing kit, and install, but you bring in your thirds. Those prices are per third member also. I can help pull the thirds @ my house and the truck can sit on my lift till he gets the thirds done if you want to plan it out accordingly, I don't supply the rags, brake clean or quick dry for the floor.
Very cool offer:)
